TwinTurbo.NET: Nissan 300ZX forum - the crack is sucking air in
aliaZ
on January 10, 2013 at 1:12 PM
2001 Ford Escape V6 3.0L..cracked manifold problem
posted by inf
on January 10, 2013 at 10:47 AM
this is causing a false lean condition, and the ECU compensates by richening the mixture
inf
10:47:40 01/10/13
It's a Ford, should be the only explanation you need. (n/m)
TriniTT
11:52:12 01/10/13
*like (n/m)
Zvil (FL)
13:28:41 01/10/13
the crack is sucking air in -
aliaZ
13:12:12 01/10/13
Is material ABS plastic? (n/m)
njz
19:41:09 01/10/13
i meant to say it's the exhaust manifold leaking on bank 1
inf
22:55:17 01/10/13
If you look at my post history you can see I had a Z
inf
23:00:10 01/10/13
sounds like your cat is clogged (n/m)
aliaZ
11:53:11 01/11/13
I do get a CL -fault reading for the fuel system though.
inf
23:01:34 01/10/13
