TwinTurbo.NET: Nissan 300ZX forum - Only use a digital VOM. The throttle body difference >>>
ZUL8TR
on January 10, 2013 at 8:57 AM
Re: Even though new is it properly set? As noted above>>
posted by Zeto32
on January 09, 2013 at 09:12 PM
needs to be adjusted (B4 the TPS is set) so they both close exactly the same as well as open the same. There is a section in the manual that tells how to adjust them. If you can't find the section let me know.
ZUL8TR in Orlando,FL
Need Help With Ignition Timing and TB
Zeto32
15:47:31 01/07/13
Do you know how to set the timing? Why are you messing with
craigz96tt (SC)
15:52:03 01/07/13
First things first
Red Hawk (CO)
16:09:54 01/07/13
Yep, this^.
TriniTT
17:52:12 01/07/13
Re: First things first
Zeto32
17:50:58 01/08/13
Re: Need Help With Ignition Timing and TB
Zeto32
17:40:24 01/08/13
The 0.45v setting on the TPS is not necessarily the >>
ZUL8TR
06:55:09 01/09/13
Re: The 0.45v setting on the TPS is not necessarily the >>
Zeto32
11:48:06 01/09/13
ZUL8TR
16:50:55 01/09/13
Zeto32
21:12:54 01/09/13
Only use a digital VOM. The throttle body difference >>> -
ZUL8TR
08:57:07 01/10/13
this might help...
Medallion Man
04:18:14 01/10/13
and this...
Medallion Man
04:49:01 01/10/13
Re: this might help...
Zeto32
02:18:28 01/11/13
I had the exact problem with timing and hesitation
Project_Broke
07:55:30 01/11/13
Re: I had the exact problem with timing and hesitation
Zeto32
18:07:52 01/11/13
