TwinTurbo.NET: Nissan 300ZX forum - Re: Re: My 1st Z Ever!!
Subject Re: Re: My 1st Z Ever!!
Posted by YoBiggHomie on January 10, 2013 at 5:39 AM
  This message has been viewed 172 times.
In Reply To Re: My 1st Z Ever!! posted by Medallion Man on January 10, 2013 at 03:23 AM
Message :unfortunately since these engines are "interference", if the timing belt goes it is extremely likely that there is other damage.
:this can be: piston, con rod, bearing, valve, cam crank.. etc.. so it's really no worth messing with an old engine unless you can have it properly and well checked over.
:However even with checks if there is a fault in a component and you rebuild with the old parts you could have a catastrophic failure further down the line... and after spending all that money who would want that?
:what are you looking for?
:a lot more power than the standard engine or just a standard system (with a few mods).
:and yes if you opt for high power you will be spending lots of money.
:best of luck.
I was thinking of a Mild build, like a stage 4 0r 5. I want the entire engine rebuilt with new pistons/cams/valves etc. but a guy at Autozone said it would be better just to replace it with a JDM Motor. If I rebuild mine, it will fit back in the car with no problem cause it come from that car.
