TwinTurbo.NET: Nissan 300ZX forum - The 0.45v setting on the TPS is not necessarily the >>
Subject The 0.45v setting on the TPS is not necessarily the >>
Posted by ZUL8TR on January 09, 2013 at 6:55 AM
  This message has been viewed 266 times.
In Reply To Re: Need Help With Ignition Timing and TB posted by Zeto32 on January 08, 2013 at 05:40 PM
Message setting. There is a range in the spec. Your goal is to rotate the TPS unit until the sensor voltage is within 0.4-0.5V, and there is continuity across the TPS switch. Ideally the TPS switch should cut off at about 900-950rpms. If you can't get both within spec at the same time you'll probably have to buy a new TPS.
See here for the details
[ http://twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=960871 ]
ZUL8TR in Orlando,FL
