TwinTurbo.NET: Nissan 300ZX forum - B4 removing ll the belts to see what accessory is >>
Subject B4 removing ll the belts to see what accessory is >>
Posted by ZUL8TR on January 09, 2013 at 6:46 AM
  This message has been viewed 210 times.
In Reply To Whirring Noise in a 1992 Z32 N/A posted by Morinkashi on January 07, 2013 at 05:15 PM
Message a possible culprit just use a thin long metal or wood stick like a dowl rod and probe the accessories while creating the noise. I have a cheap stethascope from harbor freight for just such searching saves alot of time over R&R of parts. I think you have a noisy bearing.
[ http://www.harborfreight.com/catalogsearch/result?q=stethascope ]
Did this occur before the timing belt change? If not the timing belt might be missaligned with the crank sprocked or the tensioner or ideler pulley bearings are noisy.
ZUL8TR in Orlando,FL
