TwinTurbo.NET: Nissan 300ZX forum - If they have the U shaped lock like in the photo>>>
Subject If they have the U shaped lock like in the photo>>>
Posted by ZUL8TR on January 07, 2013 at 10:02 AM
  This message has been viewed 240 times.
In Reply To Re: Have you replaced the early injectors with the 93+ >> posted by nissan300zxtt215 on January 06, 2013 at 12:19 PM
Message you replaced your injectors with the old style pintle type. Those are prone to early failure with the ethanol fuels that cause corrosion due to alcohol. Suggest you add fuel stabilizer like Sta-bil to each tank at the dose on the bottle. Walmart has good price on a quart.
Also if you ever add fuel injector cleaners pick those that have no alcohol. I always use Chevron Techron fuel system Concentrate Plus it has no alcohol and does a good job of carbon removal as well as injector cleaner.
A list of fuel additives
[ http://www.fuel-testers.com/is_gas_additive_safe_with_e10_list.html ]
ZUL8TR in Orlando,FL
