TwinTurbo.NET: Nissan 300ZX forum - Issue with rear differential bushings replacement
Subject Issue with rear differential bushings replacement
Posted by quadratique on January 06, 2013 at 7:51 PM
  This message has been viewed 528 times.
Message I've replaced the rear differential bushings with the Energy Suspension one. However, when putting back the differential, I can not align the front holes with the holes in the frame. There's about 1/4 to 3/8 inch offset. I've tried to push the diff backward to align the holes but did not work. The ES bushings extend more than the OEM and I suspect that the bushing lips are touching the diff which does not allow to push it back. Anyone had a similar issue ?
Should I shave the bushing lips ?
BTW, my car is a 1992 JDM 2+2 TwinTurbo.
Thanks
