TwinTurbo.NET: Nissan 300ZX forum - if doing an engine build does the year of the TT block,crank
craigz96tt (SC)
on January 06, 2013 at 10:56 AM
cams etc. make a difference if you're going to 88 mm bore. I do know need 40p heads but curious about other parts as far as year goes
if doing an engine build does the year of the TT block,crank -
craigz96tt (SC)
10:56:47 01/06/13
It's going in my 96 without VCT so ill have to put half moon
craigz96tt (SC)
12:14:40 01/06/13
I have all the vtc stuff if you need it. (n/m)
TriniTT
19:21:38 01/06/13
I think I'll just do the half moons cuz 96 had 20 less hp
craigz96tt (SC)
19:34:06 01/06/13
Actually there is special hardware that goes back there
ZXoltan
06:54:52 01/07/13
I'll msg you when I get closer to doing the build (n/m)
craigz96tt (SC)
13:55:23 01/07/13
If you're going to all the trouble to build, I'd add VTC.
TriniTT
11:05:25 01/07/13
Re: I thought the 20 less hp was merely a rumor
Zeke21
08:39:59 01/09/13
year doesn't matter (n/m)
aliaZ
14:35:58 01/06/13
Thanks Don (n/m)
craigz96tt (SC)
14:37:40 01/06/13
There are some subtle differences between earlier and later
ZXoltan
07:02:29 01/07/13
I wasn't aware of changes in oil jet size
aliaZ
17:21:13 01/07/13
Its actually a check valve not the jet
ZXoltan
20:27:39 01/07/13
Re: Its actually a check valve not the jet
Tech@EPR
05:05:37 01/08/13
BDE Link
thumper (Los Angeles)
20:50:57 01/10/13
