TwinTurbo.NET: Nissan 300ZX forum - You're referring to the eccentric bolt adjuster.
Subject You're referring to the eccentric bolt adjuster.
Posted by TriniTT on January 06, 2013 at 8:06 AM
  This message has been viewed 308 times.
In Reply To rear adj camber arm bolt twisted onto asymetrical washer/adj posted by scoops on January 04, 2013 at 07:01 PM
Message The washers have a tendency to slip under load, and they really don't offer much functionality. I recommend replacing them with the eccentric lockout kit that SPL sells and using adjustable arms to dial in your alignment. As far as removing it now, I slip a flathead into the tightest spot between the washer and subframe, then turn the bolt while the washer is stuck in place. If you plan to remove it entirely and replace it, I've also had success tapping the bolt out with a hammer, effectively destroying the threads on the bolt.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
