TwinTurbo.NET: Nissan 300ZX forum - Re: rear adj camber arm bolt twisted onto asymetrical washer/adj
ryzan
on January 05, 2013 at 7:42 PM
posted by scoops
on January 04, 2013 at 07:01 PM
I had this same problem the other day, I just got a small flathead and jammed it into one of the grooves in the washer then tapped it with a hammer until I could get it out.
scoops
19:01:06 01/04/13
What do you mean "twisted onto"? (n/m)
zellamay
22:57:26 01/04/13
you should post a pic
Shiers69
01:26:26 01/05/13
Be hard to tell in a pic; twisted means the 'keys'
scoops
16:46:41 01/05/13
Just pulled some with that same issue
Broke_as_****
16:50:55 01/05/13
Re: rear adj camber arm bolt twisted onto asymetrical washer/adj -
ryzan
19:42:34 01/05/13
You're referring to the eccentric bolt adjuster.
TriniTT
08:06:39 01/06/13
