TwinTurbo.NET: Nissan 300ZX forum - He should have done the valve cover seal at that time >>
Subject He should have done the valve cover seal at that time >>
Posted by ZUL8TR on December 31, 2012 at 8:59 AM
  This message has been viewed 284 times.
In Reply To Re: All good advice above. With the valve cover leak clean>> posted by tsahlin489 on December 30, 2012 at 09:34 PM
Message if it was leaking. Do you know if the late model injectors were put in? You can tell by the connectors, the old style use a U shaped clip that had to be pulled out to release the conector the new style have a plastic tab that is pressed to release the connector. The late model injectors are better than the old style ans supposedly less prone to failure from ethanol fuel.
ZUL8TR in Orlando,FL
