TwinTurbo.NET: Nissan 300ZX forum - 2nd on the charger
2nd on the charger
ZXoltan
on December 31, 2012 at 4:47 AM
Not enough juice to run a comprssion test?
posted by Tanley
on December 30, 2012 at 07:17 PM
If the engine isnt spinning fast enough you're compression will look artificially low and the test is a waste of time
Tanley
19:17:16 12/30/12
Did you remove all of the spark plugs?
Broke_as_****
21:44:18 12/30/12
Yeah, all of the spark plugs were out, throttle jammed open.
Tanley
22:21:06 12/30/12
Intake pipes on shouldn't be an issue (n/m)
Broke_as_****
09:44:32 12/31/12
2nd on the charger -
ZXoltan
04:47:23 12/31/12
Can you a recommend a good charger for under $100?
Tanley
07:58:09 12/31/12
If you got a good set of jumper cables just hook up a
Evan_Wright (Ca)
12:01:42 12/31/12
I thought about that.
Tanley
13:02:54 12/31/12
Got it all figured out, thanks for all of the help.
Tanley
19:22:45 01/01/13
