TwinTurbo.NET: Nissan 300ZX forum - Re: Some questions about my Z
Subject Re: Some questions about my Z
Posted by Hipendicular on December 28, 2012 at 9:41 PM
  This message has been viewed 286 times.
In Reply To Some questions about my Z posted by tsahlin489 on December 28, 2012 at 03:02 PM
Message These are very common problems for a Z. I had almost everyone when I picked up my Z. The sloppy shifter is probably shifter bushings, mine were completely gone. I doubt the leaking ps fluid is coming from the boots. Mine has torn boots and I'm not leaking, but its probably your high pressure line or another PS hose line, again very common.
The brake light is from a blown bulb or wrong bulbs installed. I had this again when I swapped to JDM tail lights, I just swapped in all my stock bulbs and problem fixed. The loud shifter might be from missing or torn shift boots.
Listen to Antihero for your cluster.. probably a bad solder joint.
I hope its the common stuff as any Z with some miles, has had these problems. Oh and the valve cover gasket is an expensive or labor intensive project.. Good luck
Ken 91TT
P.s. And tighten all your fuel lines, my car again got a leak so bad it started dripping. A few mins with a screwdriver and it was fixed.. (Search fuel smell)
