TwinTurbo.NET: Nissan 300ZX forum - Couldn't the speedo also just be the sensor?
Subject Couldn't the speedo also just be the sensor?
Posted by BlackholeZ on December 28, 2012 at 10:30 PM
  This message has been viewed 336 times.
In Reply To member DVDBurn can fix your speedo. posted by Antihero on December 28, 2012 at 04:01 PM
Message If the connector is intermittent I could imagine that it would behave similarly.
When it is up in the air, check and make sure that the speed sensor is properly connected, the connectors are not broken, and the pins are clean. When you do the shifter bushings would be the perfect time.
-Dan
BlackholeZ VTC Solenoid Caps
Installation Procedure
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" - ChristopherTheOne
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
"You're the Skrillex of Z32s." BradX (UF)
