TwinTurbo.NET: Nissan 300ZX forum - They bolt the transmission bellhousing to the motor!
Subject They bolt the transmission bellhousing to the motor!
Posted by JonnyZ(SoCal) on December 27, 2012 at 8:07 PM
  This message has been viewed 354 times.
In Reply To What do the bolts do??? posted by boostlv on December 27, 2012 at 05:49 PM
Message The leak could be coming from your rear main seal, oil pan, rear seal holder, trans...
When you tightened the bolt it probably just let the oil leak into the bell housing and take longer to show it.
Your car is shifting better now because the trans was most likely a little crooked and the shaft wasn't properly aligned until you tightened it!
If you ever need a Z mechanic again you can contact me and I can probably do the work for you at the shop I work at. We work on supras but I have been in the Z game for 3 years before I touched a supra. You can contact me through email or add me on FB if you have one. Either way feel free to contact me if you ever need help too!
