TwinTurbo.NET: Nissan 300ZX forum - Re: Hrmm
Subject Re: Hrmm
Posted by backinblack626 on December 27, 2012 at 8:12 AM
  This message has been viewed 187 times.
In Reply To Hrmm posted by Summeronthechain (MN) on December 27, 2012 at 07:40 AM
Message The timing marks are on the lower timing cover not the oil pump. Are they on the oil pump as well? They have the marks that line up with the notch on the crank pulley on that cover. And I have already become a master of the helicoil haha! Both hatch strut bolts stripped, both balance tube bolts, my seat belt bolt is even stripped. I saw coolant white flakes around my coolant temp sensor (ecu) and around the edges of the hoses. It was from the pitting or break down of the aluminum from the ethylene glycol I believe. Jb weld worked AWESOME to fill the pits. Also Ford makes this high temp anticorrosive flat black paint that works perfect as a base coat before paint.
Thanks for the suggestions.
