TwinTurbo.NET: Nissan 300ZX forum - I'd use a test light to check it.
Subject I'd use a test light to check it.
Posted by TriniTT on December 22, 2012 at 5:42 PM
  This message has been viewed 170 times.
In Reply To Remote hatch release question (94 and later Z owners) posted by JMartz on December 22, 2012 at 09:56 AM
Message Have you checked all of your fuses? It could be a faulty key fob too, though, but if you test find the signal by checking the wires back in the hatch as you attempt to click it, if you see no response you can check up front where the brain control box is (don't quote me on that, I'm not positive where the brain is without looking but iirc per jodecys alarm install post from years ago it's near the ecu). You can look up the alarm install writeup to test different areas to see if your fob is performing, but if you make no progress I'd probably recommend testing a new fob before changing the brains of the alarm system out.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
