TwinTurbo.NET: Nissan 300ZX forum - If the cams are in the heads have the Bank2 cams with the
Subject If the cams are in the heads have the Bank2 cams with the
Posted by nissanguyz32 on December 21, 2012 at 10:49 PM
  This message has been viewed 168 times.
In Reply To heads & timing belt question. posted by ariz on December 21, 2012 at 12:05 PM
Message dowel pins up cams in neutral position(no valves open). Bank 2 stays this way for timing belt install. For Bank 1 if cams are installed roll the cams so the dowel pins are up and then slowly rotate to the left till they sit in a neutral position.
Once you install the heads,gears and ready to install the belt you will be able to roll the cams(bank1) up to their alignment dots.
Keyway on crank pointing at Bank1 for head install(TDC).
