TwinTurbo.NET: Nissan 300ZX forum - Re: heads & timing belt question.
Subject Re: heads & timing belt question.
Posted by Cjw3 on December 21, 2012 at 1:42 PM
  This message has been viewed 170 times.
In Reply To heads & timing belt question. posted by ariz on December 21, 2012 at 12:05 PM
Message I'm a Devoted Chicken.. So I took the cowards way on this one..
I put the Crank at 30 Deg BTDC for number one.. Then I bolted up the Heads and did all the Cam Fussing to get everything in and Allinged.. Then put the Cams at the Marks, and Then Advanced the Crank to TDC for Number One.. then aseembled the belt
If the Crank is at 30 Deg BTDC for number one, the Valves will clear the Pistons.. but they still wont Clear each other at full lift, so be carefull when you turn the Cams Separatly..
Cj
