TwinTurbo.NET: Nissan 300ZX forum - Re: Bad rear-end vibration on incline and letting out clutch.
Subject Re: Bad rear-end vibration on incline and letting out clutch.
Posted by charleyd on December 18, 2012 at 8:33 PM
  This message has been viewed 286 times.
In Reply To Bad rear-end vibration on incline and letting out clutch. posted by evan_aggie on December 15, 2012 at 03:55 PM
Message Mine does exactly the same thing. Sounds/feels like something is about to fall out of the rear end (Like you said - bouncing around.). I am convinced it is due to clutch chatter combined with a worn trans. I have a lightweight flywheel and a puck-style friction disk. Neither the trans nor the diff are original, so mileage unknown. I have removed the exhaust, the one-piece driveshaft, and the complete rear suspension. I opened-up and inspected the diff, and inspected the axles and wheel bearings. Everything looks fine. I know that my trans is worn because of various gear-type noises that it makes. My plans now are to get a full-face friction disk and overhaul or replace my transmission. How long have you had the FE disk?
