TwinTurbo.NET: Nissan 300ZX forum - I've seen others do it but
Subject I've seen others do it but
Posted by arkansasturbo on December 18, 2012 at 6:30 PM
  This message has been viewed 172 times.
In Reply To The reason it's an air bleed hole is because it's above the posted by craigz96tt on December 18, 2012 at 02:55 PM
Message You do raise a good point about constant sensor coverage. I assumed that since the water from the engine was constantly flowing right underneath that location it would be okay.
I also am under the impression that there will not be any air bubbles in the cooling system, in a properly bleed system. The coolant overflow tank allows for this in both cold and hot cooling states. This is, after all, why we burp ALL the air out of the system, correct?
Something else to consider, I am not using this from anything ECU related, strictly a gauge.
