TwinTurbo.NET: Nissan 300ZX forum - Not to worry it will pass an emission test also. The code
Subject Not to worry it will pass an emission test also. The code
Posted by craigz96tt on December 18, 2012 at 3:17 PM
  This message has been viewed 293 times.
In Reply To 1996 Code 87 Evap help posted by Zeke21 on December 18, 2012 at 06:46 AM
Message will stay on there until you repair it and if you've gotten a good look at the vacuum tubing going to the boost solenoids and frpvr it's scary but the under hood temps on our cars are such that rubber hoses will only last so many years. My suggestion to you is to replace all you can with silicone hose because in the world of OBDII a small vacuum leak will send the car to code and unless repaired it will just keep coming back on. Good luck and keep the shiny side up
