TwinTurbo.NET: Nissan 300ZX forum - It's not a dangerous code.
Subject It's not a dangerous code.
Posted by TriniTT on December 18, 2012 at 9:40 AM
  This message has been viewed 310 times.
In Reply To 1996 Code 87 Evap help posted by Zeke21 on December 18, 2012 at 06:46 AM
Message There are several connectors/solenoids on the ds near the fuse block that could cause you to throw this code. Check all the connectors in that area. Make sure you have no vacuum leaks in any of the 142+ vacuum lines in that area. A third offender could be your gas cap, try to open the cap and see if it's holding pressure. In the same area, there's a solenoid accessible near the ds rear wheel well that can throw that code, check vacuum lines and connectors there as well.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
