TwinTurbo.NET: Nissan 300ZX forum - Sure - they just eliminated the electrical part (in rear
Subject Sure - they just eliminated the electrical part (in rear
Posted by jzack on December 15, 2012 at 6:56 AM
  This message has been viewed 137 times.
In Reply To So could there still be a major leak there posted by syphon0202 on December 14, 2012 at 11:36 PM
Message of engine), the car's ECU programming and the most expensive part - the specially made CAM sprockets that had complicated internal machining to allow it to be variable. Main issue was cost cutting as I understand it....
This issue could be as simple as someone did a CAM seal replace and was careless in fastening down those bolts when re-installing the CAM gear. Over time, due to spinning, things came loose...
PS -- There's a pretty good chance the timing belt will need to be replaced, if not at least completely cleaned. Since you've got everything apart - really not that big of a deal to do workwise. Main concern is how oil soaked the belt got...
