TwinTurbo.NET: Nissan 300ZX forum - Those CAMs are part of a variable intake timing system
Subject Those CAMs are part of a variable intake timing system
Posted by jzack on December 14, 2012 at 6:11 PM
  This message has been viewed 154 times.
In Reply To Oil leak troubleshooting posted by syphon0202 on December 14, 2012 at 04:22 PM
Message which is controlled by oil pressure. Those covers have an O-ring behind them to prevent leaks. I'd get new O-rings, then re-install the covers, tightening the bolts to spec(15 ft/lbs if I remember correctly?) Not a bad idea to apply some (mild) lock-tight to the threads as well - you may notice some factory residue on the bolt heads from adhesive used when first assembled (white in color).
Please be aware - behind those CAM covers are some strong springs, take care when removing the covers that they don't pop out and hit you. Not big deal, you'll easily be able to put it all back together with no issues...
