TwinTurbo.NET: Nissan 300ZX forum - There is no logic there.
Subject There is no logic there.
Posted by TriniTT on December 14, 2012 at 9:04 AM
  This message has been viewed 217 times.
In Reply To Re: so is oil leaking from your tranny or your engine? posted by boostlv on December 13, 2012 at 02:36 PM
Message Owning a Z and not being taken for a ride by a mechanic requires some intuition. Use the search function as a resource as much as possible. Manual transmissions don't tend to leak, and they never leak from the front of the bellhousing unless there's a MAJOR issue.
Everything about a vehicle has to obey physics. That means, gravity pulls fluids down and the force of the vehicle moving forward pushes the fluid back. So it's standard for an oil leak to drench your transmission bellhousing.
The main thing you need to address is this: you paid a mechanic to fix a problem he did not fix. Excuses are not acceptable, with a business transaction if you end up in a worse situation than you started then something isn't right.
As far as getting it fixed, listen to aliaZ, because he's probably right. The average z owner on this forum can tell you about the rear main seal and retainer leak issues; it seems like your "Z mechanic" should know all about it, too.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
