TwinTurbo.NET: Nissan 300ZX forum - For no issues use Red Line M/T 90 in trans for best results (n/m)
craigz96tt
on December 13, 2012 at 11:32 AM
Re: Clutch install/ worse leak now!
posted by boostlv
on December 13, 2012 at 10:21 AM
boostlv
10:09:32 12/13/12
boostlv
10:21:28 12/13/12
For no issues use Red Line M/T 90 in trans for best results (n/m) -
craigz96tt
11:32:45 12/13/12
I use Amsoil, no difference in shifts no matter the temp. (n/m)
TriniTT
15:00:07 12/13/12
so is oil leaking from your tranny or your engine? (n/m)
Zvil (FL)
10:55:01 12/13/12
Re: so is oil leaking from your tranny or your engine?
boostlv
14:36:32 12/13/12
If your tranny is leaking then your mechanic is an Idiot
Zvil (FL)
00:54:36 12/14/12
There is no logic there.
TriniTT
09:04:37 12/14/12
Sounds like you need to go back to that mechanic (n/m)
craigz96tt
11:15:12 12/13/12
Or quite specifically, never go back to him again. (n/m)
TriniTT
11:17:17 12/13/12
Definitely. Anyone that can't install a rear main shouldn't
craigz96tt
11:39:40 12/13/12
The guy did not know the Z32 seal replace procedure.
ZUL8TR
11:38:43 12/13/12
Here's his link
boostlv
14:34:27 12/13/12
Re: Here's his link
boostlv
14:38:03 12/13/12
are you sure it is your rear main seal?
aliaZ
18:08:05 12/13/12
Re: are you sure it is your rear main seal?
cygate
20:18:32 12/13/12
Re: Re: are you sure it is your rear main seal?
boostlv
10:08:48 12/14/12
