TwinTurbo.NET: Nissan 300ZX forum - When you go to put it back together
Subject When you go to put it back together
Posted by Broke_as_**** on December 12, 2012 at 2:32 PM
  This message has been viewed 182 times.
In Reply To Re: Pull radiator, unbolt ac compressor, unbolt bracket. posted by ZBOOSTT on December 12, 2012 at 07:45 AM
Message Get the oil line installed and the banjo bolt tightened. Then apply some anti-seize or silicone or anything else goopy that you can spread thin across the top of the banjo bolt and oil line. Carefully install the AC bracket and then remove it, if there was any transfer to the back of the bracket you have some cutting to do.
