TwinTurbo.NET: Nissan 300ZX forum - Valve direction is right from what I recall - makes sense
Subject Valve direction is right from what I recall - makes sense
Posted by jzack on December 11, 2012 at 11:06 PM
  This message has been viewed 196 times.
In Reply To Heater valve -- finally got to it...however... posted by thumper300zx on December 11, 2012 at 12:13 PM
Message since heat is coming out too. Would guess the flap motor for the vents also went bad - therefore not the right mix at your feet. Have you tried running in the Recirculate mode -- that is, with the outside air inlet closed? It should may but will also increase moister/frosting issues on the glass inside the car...
