TwinTurbo.NET: Nissan 300ZX forum - a blown center carrier bearing wont cause the car to shake
Subject a blown center carrier bearing wont cause the car to shake
Posted by RonDeezy on December 10, 2012 at 9:29 PM
  This message has been viewed 212 times.
In Reply To shakin bakin posted by touger on December 10, 2012 at 10:23 AM
Message in the way you described. but like zvil said, two different tires on the same axel isnt ideal at all. get your tire situation sorted out, then have the alignment done. if after these post youre curious about your center carrier bearing you can check on it pretty easy if youre able to get under your car. all you have to do is grab your driveline and see how much it moves. the bearing on the two piece that came with my car was completely blown, allowing A LOT of play in how much i was able to wiggle it. good luck with your issue.
