TwinTurbo.NET: Nissan 300ZX forum - Help can't reach banjo bolt from block leaking
Subject Help can't reach banjo bolt from block leaking
Posted by ZBOOSTT on December 09, 2012 at 4:43 PM
  This message has been viewed 351 times.
Message I have a leaking oil feed line on the driver's side. It looks clearly like it is coming out of the banjo bolt into the block connection where my SZ SS oil feed line starts from. I can not get to that bolt to tighten it because the A/C bracket seems to be covering it. Can anyone reach that, or does the A/C bracket have to be removed first? Is it 15mm or 17mm? Cant remember. Anyway, any trick to reaching that bolt?
