TwinTurbo.NET: Nissan 300ZX forum - Stock head bolts = OEM head bolts
Subject Stock head bolts = OEM head bolts
Posted by ttsmokin on December 06, 2012 at 5:44 PM
  This message has been viewed 305 times.
In Reply To I cannot reuse stock head bolts but ok with OEM head bolts? posted by tt_703 on December 06, 2012 at 03:17 PM
Message Antihero is correct. I was meaning that you should throw away the head bolts you have and buy a new set of OEM head bolts (~$75 IIRC).
I did once re-use the head bolts when I had no idea they were torque to yield bolts. It was because of a oil leak from the head gasket on a rebuild someone else did. No idea how they managed to mess up but I re-used the stock bolts without issue. But I only had that engine for 5-8 thousand kms. No idea if it would have lasted or caused future issues (ended up getting rebuilt again from a cracked ring land). It's not worth the stress to cheap out.
