TwinTurbo.NET: Nissan 300ZX forum - Re: software/diagnostic
Subject Re: software/diagnostic
Posted by JonnyZ(SoCal) on December 06, 2012 at 12:53 AM
  This message has been viewed 165 times.
In Reply To software/diagnostic posted by jlopezZ on December 05, 2012 at 08:32 PM
Message Check your ecu for codes (search how to do this)
Check your timing, tps voltage, alternator voltage, battery, fuel injector ohm, spark plugs and maf for a start.
You can buy software to check these things but if you can't do it manually it won't help much.
There are many things it could be so make sure to use the search bar quite a bit.
