TwinTurbo.NET: Nissan 300ZX forum - You're looking at the gauge temp sensor. You need to fix
Subject You're looking at the gauge temp sensor. You need to fix
Posted by TriniTT on November 29, 2012 at 4:11 PM
  This message has been viewed 135 times.
In Reply To Re: I would put money on your temp sensors. posted by jessethehitman on November 28, 2012 at 02:52 PM
Message the engine control temp sensor. You have 2 sensors on the water pipe on the front of the engine that are clearly visible and accessable. The one with a single wire goes directly to your gauge cluster to show you the water temp. The larger connector with 2 wires is the engine control temp sensor, and they're notorious for developing corrision on the contacts. Remove the connector and clean off all the green corrosion that I guarantee you is there, use some dielectric grease on the contacts before reconnecting and that should fix your problem.
I highly doubt it has any relevance to your jwt chip.
Cheers,
JBrobst
"A life spent making mistakes is not only more honorable, but more
useful than a life spent doing nothing." George Bernard Shaw
