TwinTurbo.NET: Nissan 300ZX forum - I would do a compression test and check with a flashlight
Krazyd27(Houston)
on November 29, 2012 at 8:04 AM
Diagnose this...while road racing 2 weekends ago, i noticed
posted by sawbonez
on November 28, 2012 at 07:11 PM
The top surface of that piston for damage from that spark plug blowing out.
sawbonez
19:11:30 11/28/12
Jeesh! Keep us posted.
OverZealous (CT)
20:06:49 11/28/12
I would do a compression test and check with a flashlight -
Krazyd27(Houston)
08:04:53 11/29/12
top of piston looks ok, compression test pending i have
sawbonez
08:16:05 11/29/12
Yes get a look inside # cylinder. (n/m)
craigz96tt
08:10:48 11/29/12
Could be as simple as a faulty spark plug that just
MixManMash
10:07:59 11/29/12
ngk bkr7eix (n/m)
sawbonez
13:52:36 11/29/12
Sounds like maybe your MAF signal failed, allowing
TriniTT
11:22:35 11/29/12
ok
aliaZ
19:07:19 11/29/12
hmm...i don't think my car will do 145-150 mph in safe mode
sawbonez
07:08:17 11/30/12
That turn is when your MAF connector lost connectivity. (n/m)
TriniTT
13:56:32 11/30/12
got it now....i'm a little slow.. so my plan is as follows:
sawbonez
16:05:15 11/30/12
Just start with the compression test, it'll save time & $.
TriniTT
16:28:38 11/30/12
last time i killed a spark plug it took out my valve too.
Dane (Houston)
16:14:41 11/30/12
you can sort of flow test a injector in car
Dane (Houston)
16:25:01 11/30/12
you guys make me want to have a bone fire party with my
sawbonez
16:44:45 11/30/12
high EGT's due to retarded timing since you were running
ztunerz
10:32:48 12/01/12
thanks harry (n/m)
sawbonez
12:40:23 12/01/12
