TwinTurbo.NET: Nissan 300ZX forum - What do you mean by timing is perfect? To >>>
Subject What do you mean by timing is perfect? To >>>
Posted by ZUL8TR on November 29, 2012 at 6:21 AM
  This message has been viewed 216 times.
In Reply To Engine break in. posted by Z-ladiesman on November 27, 2012 at 06:50 PM
Message absolutly check for correct timing did you do this? Turn the engine and put #1 cylinder at TDC of its Compression stroke then the TDC timing mark on the crank should line up with the stationary pointer on the block as well as the 4 cam pullies timing marks lining up with their stationary marks on the heads. At that position cam and crank are in time and the correct number of teeth between pullies should be the correct count.
ZUL8TR in Orlando,FL
