TwinTurbo.NET: Nissan 300ZX forum - Diagnose this...while road racing 2 weekends ago, i noticed
Subject Diagnose this...while road racing 2 weekends ago, i noticed
Posted by sawbonez on November 28, 2012 at 7:11 PM
  This message has been viewed 305 times.
Message a few episodes of overboosting to +- 20 psi, engine conservatively tuned to 20 psi on 100 octane. 30 min race ambient temp around 45F all was well. second session... after 20 min, sudden loss of 25% power. i quit the same lap parked the car. data as follows:
no smoke, no abnormal noises, did manage 125 mph just prior to pits even with power loss, so no evidence of a "catastrphic failure"
boost leak test= no significant leak
#4 cylinder "dead" per power balance test
electrode totally burned off #4 spark plug
#4 coil pack good
#4 injector nominal ohm resistance
#4 injector has power from battery
#4 injector harness in continuity with ECU harness
ECU codes detonation sensor 14 times as expected...
MAF code 9 times
555cc injectors and wiring harness 5 years old
as i don't have an easy or efficient way to test the flow of the injector, my plan is to replace the injector first then evaluate both MAFs... i think the root cause of the lean condition in #4 cylinder is low fuel secondary to failed injector
