TwinTurbo.NET: Nissan 300ZX forum - Kinda common.
Subject Kinda common.
Posted by Woody75 (Denver) on November 28, 2012 at 9:24 AM
  This message has been viewed 176 times.
In Reply To shifter assembly problem posted by ztorque on November 27, 2012 at 07:13 PM
Message The top section of the shifter has come loose from the rubber material inside it. The rubber bonds the upper and lower halves of the shifter together as well as dampens vibrations and heat. Once the rubber breaks loose it allows the top portion of the shifter to spin. You need to be able to grab the upper half of the shifter that the shift knob screws onto and hold it. May have to take a bunch of stuff apart to give yourself access to that area. Might have to take the whole shifter out of the car with the console still attached as well.
Once apart, you can drill and insert a pin all the way across. This will lock the upper and lower halves of the shifter together and keep it from turning.
I have lots of shifter cores that turn like this. I never used them to make my short shifters as I didnt want customers having this same issues. I'm looking at using some now using the pin method. I have done one this way and it has held up fine so far.
JackB nimble JackB quick JackB can suck my dick =P - james-lee 11/02/01
Arrogance is the #1 weapon against Supra Owners - MikeH 08/06/02
Dallas with a Z: I like the bulge dude 05/02/03
Bezbefootball: Does dick have anything for me? 10/21/03
