TwinTurbo.NET: Nissan 300ZX forum - No smoke out of the exhaust. And no coolant in oil.
Subject No smoke out of the exhaust. And no coolant in oil.
Posted by Krazyd27(Houston) on November 26, 2012 at 2:36 PM
  This message has been viewed 169 times.
In Reply To then I should have oil in the coolant correct? or vice versa posted by LJZTT on November 26, 2012 at 12:57 PM
Message The temperature would slowly creep up whenever it wanted to, and every third day had to be topped off with coolant. A turbo hose on the passenger side was leaking and would only squirt water under boost. Nonetheless the gurgling could be due to either a bad hg or air in your system. The compression test was around 140 on all cylinders but the hg was bad when the heads were pulled.
