TwinTurbo.NET: Nissan 300ZX forum - Fitting won't work
Subject Fitting won't work
Posted by NextZ on November 26, 2012 at 1:10 PM
  This message has been viewed 162 times.
Message I bought the 90 degree fitting that relocates the oil pressure sensor. The fitting is used to prevent the oil pressure sensor from hitting the turbo. The problem is when I tighten the fitting down it stops right where the oil filter goes. I thought about grinding down the threads so the fitting would bottom out without interfering with the oil filter. Any other suggestions?
