TwinTurbo.NET: Nissan 300ZX forum - I'll be the bad guy and bring it up. Head gasket?
zellamay
on November 26, 2012 at 12:15 PM
Gurgling/sizzling/bubbling noise seems to be coming from the
posted by LJZTT
on November 26, 2012 at 07:36 AM
That "gurgling" is often the first indicator. Hope I'm wrong.
07:36:08 11/26/12
That means you have a leak or air in the system so if you...
craigz96tt
08:51:06 11/26/12
I found your reply a bit confusing
14:22:42 11/26/12
I'll be the bad guy and bring it up. Head gasket? -
zellamay
12:15:33 11/26/12
Last engine I had did the same gurgling except
Krazyd27(Houston)
12:20:49 11/26/12
no other symptoms? How did you know the two were related? (n/m)
14:29:39 11/26/12
then I should have oil in the coolant correct? or vice versa
12:57:24 11/26/12
No smoke out of the exhaust. And no coolant in oil.
Krazyd27(Houston)
14:36:52 11/26/12
hm, mine are all 150-160 except for one @ 140
14:55:38 11/26/12
Car ran fine, idle was steady with a miss or so every minute
Krazyd27(Houston)
16:02:07 11/26/12
The quick easy check is for combustion gases in the radiator
zellamay
19:55:42 11/26/12
hm, I'm really not leaning towards this
11:44:06 11/27/12
I hope you're right. Yes, both times I lost a hg, it was
zellamay
12:10:40 11/27/12
