TwinTurbo.NET: Nissan 300ZX forum - Re: Exhaust heat shields, exhaust hangers worn that are bolted
ztorque
on November 25, 2012 at 9:01 AM
posted by craigz96tt
on November 25, 2012 at 07:26 AM
i just recently change my catback and everything look good with the exhaust and the thing is the noise is only like i said before when I'm on a high gear and i slow down and then I'm suppose to shift to a low gear but i continue on a high gear.
weird rattle noise while driving
ztorque
10:11:16 11/24/12
Driveshaft, clutch, throw out bearing, maybe loose exh. bolt
Krazyd27(Houston)
11:01:02 11/24/12
Re: Driveshaft, clutch, throw out bearing, maybe loose exh. bolt
ztorque
12:27:56 11/24/12
Inspect your center carrier bearing
Krazyd27(Houston)
13:37:43 11/24/12
Re: Inspect your center carrier bearing
ztorque
15:19:29 11/24/12
craigz96tt
07:26:56 11/25/12
Re: Exhaust heat shields, exhaust hangers worn that are bolted -
ztorque
09:01:30 11/25/12
If noise started after exhaust install still inspect it all (n/m)
craigz96tt
10:02:09 11/25/12
Re: If noise started after exhaust install still inspect it all
ztorque
19:22:25 11/25/12
