TwinTurbo.NET: Nissan 300ZX forum - Inspect your center carrier bearing
Subject Inspect your center carrier bearing
Posted by Krazyd27(Houston) on November 24, 2012 at 1:37 PM
  This message has been viewed 290 times.
In Reply To Re: Driveshaft, clutch, throw out bearing, maybe loose exh. bolt posted by ztorque on November 24, 2012 at 12:27 PM
Message If your driveshaft is stock chances are your center carrier bearing might be going out. Normally the symptoms always occur when first taking off or shifting then it smooths out on its own after acceleration. Jack up your car securely and check if there is any play in the driveshaft.
