TwinTurbo.NET: Nissan 300ZX forum - The Idle On status can be obtained by either the Idle Switch
Subject The Idle On status can be obtained by either the Idle Switch
Posted by Gordo 93TT Daytona on November 23, 2012 at 10:41 PM
  This message has been viewed 218 times.
In Reply To Re: here you go tps mod is in there posted by puchy on November 23, 2012 at 06:12 PM
Message connector located on the front of the TPS, or as a result of the ECU reading the TPS voltage. On a properly functioning engine, if the Idle Switch is disconnected, the ECU will still recognize On Idle status based on the voltage reading, usually a little below 0.50 volts. Likewise, the TPS connector can be disconnected, and while the engine will idle very rough and hunt for its intended idle range; the ECU will obtain and display an On Idle status based on the on/off function of the Idle Switch connector. I am not sure how these facts might figure into your situation; however, I wanted to present them nonetheless. g.
_________________________________________________
