TwinTurbo.NET: Nissan 300ZX forum - Wow, how the hell did that happen?? Well youve exhausted
Subject Wow, how the hell did that happen?? Well youve exhausted
Posted by jmt-z on November 23, 2012 at 6:58 PM
  This message has been viewed 183 times.
In Reply To Timing Belt cover bolt help posted by JUNz (?00)rwhp on November 23, 2012 at 05:53 PM
Message the most logical means, outside of using a different kind of extractor maybe...... My only suggestion I can think of would be to use a left hand threaded tap and basically tap the inside of the hole until the tap bottoms out and use it to try to turn the bolt loose. With the size of the hole in those bolts the tap should have a stiff enough shank to possibly break them loose.
"If everything seems under control, you're just not going
fast enough."
- Mario Andretti
