TwinTurbo.NET: Nissan 300ZX forum - TPS close switch adjustment after 60mm install....
Subject TPS close switch adjustment after 60mm install....
Posted by puchy on November 23, 2012 at 2:31 PM
  This message has been viewed 253 times.
Message After installation of the larger throttle bodies I did the following:
Adjusted the set screws at the full close position of the plates.
Adjusted the maximum opening of the plates at the 90 deg. position.
Adjusted the TPS at .45v in the close position.
I ended up having an idle of 2K rpm. I went ahead and connected the Conzult and noticed the TPS wont see the close switch made anywhere above .28v. Is that normal with larger Throttles? Am I missing something?
