TwinTurbo.NET: Nissan 300ZX forum - Dang! I tried replacing booster on my 91' TT without pulling
Evan_Wright (Ca)
on November 21, 2012 at 1:30 PM
And the saga continues
posted by MidLifeZ (DFW)
on November 21, 2012 at 11:05 AM
dash and couldn't make it happen. Spent to many hours trying and then still ended up pulling dash. Good job and good luck!
I give up; Clutch bleed or other issue..
MidLifeZ (DFW)
11:49:29 11/19/12
Are you only bleeding from the slave?
JonnyZ(SoCal)
12:13:16 11/19/12
my theory for why it took longer for you is
Zvil (FL)
13:06:13 11/19/12
That's what I heard, but searching the forum a lot of people
JonnyZ(SoCal)
14:31:14 11/19/12
Try to bench bleed the clutch master cylinder
tt_703
12:37:41 11/19/12
Info on bench bleeding the master cylinder?
MidLifeZ (DFW)
15:27:13 11/19/12
Re: Info on bench bleeding the master cylinder?
tt_703
19:05:31 11/19/12
did you check the pushrod length like I mentioned before?
aliaZ
12:38:40 11/19/12
Pushrod in the slave? No did not ck that..
MidLifeZ (DFW)
15:25:39 11/19/12
I posted a link in your prior post (n/m)
aliaZ
17:42:02 11/19/12
pushrod in the master
aliaZ
17:44:01 11/19/12
yes, repalced the pivot ball and
MidLifeZ (DFW)
17:55:32 11/19/12
Re: yes, repalced the pivot ball and
aliaZ
18:53:18 11/19/12
plan for tonight..
MidLifeZ (DFW)
10:03:52 11/20/12
MidLifeZ (DFW)
11:05:55 11/21/12
Dang! I tried replacing booster on my 91' TT without pulling -
Evan_Wright (Ca)
13:30:37 11/21/12
Yeah, I was stunned I got it swapped out too! especially
MidLifeZ (DFW)
14:46:05 11/21/12
2 thoughts
Zvil (FL)
13:03:42 11/19/12
Doubt those are the issue
MidLifeZ (DFW)
15:29:29 11/19/12
just sharing thoughts, if you got it then make it happen ;) (n/m)
Zvil (FL)
15:48:15 11/19/12
Thinking since have SS clutch lines anyway will
MidLifeZ (DFW)
15:42:37 11/19/12
Get a helper, or buy speedbleeder. (n/m)
Summeronthechain (MN)
08:07:24 11/20/12
Explain this a little better?
Joe@ZSpeedperformance
00:01:49 11/22/12
Answers
MidLifeZ (DFW)
09:45:52 11/22/12
considering that it happened suddenly while at a stop light
aliaZ
10:11:04 11/22/12
2nd, could also be a fork/TOB retainer issue.
TriniTT
09:50:13 11/23/12
A couple things:
rojoloco (VA Beach)
04:22:17 11/22/12
Measurements are
MidLifeZ (DFW)
12:09:30 11/22/12
Does your Z still have..
90GoldZ
19:30:10 11/22/12
never had it.. AT>MT swap (n/m)
MidLifeZ (DFW)
09:35:20 11/23/12
Re: never had it.. AT>MT swap
Tech@EPR
20:50:50 11/23/12
