TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Thanks for the help - I think I know the problem
dwverzwy
on November 18, 2012 at 8:37 PM
posted by aliaZ
on November 18, 2012 at 07:08 PM
Yeah I took the connectors off and ohmed the injectors found them to be 27+ ohms on the misfiring cylinders and 12 on the correct ones.
I am very intimidated at the thought of a plenum pull to replace them....
Boost Leak Test vs. Vacuum Leak Test
dwverzwy
12:27:36 11/18/12
Boost leak will be between turbo and inter cooler and vacuum
craigz96tt
12:52:08 11/18/12
Re: Boost leak will be between turbo and inter cooler and vacuum
dwverzwy
13:10:50 11/18/12
I made mine but you can find a gauge with a valve stem for
craigz96tt
13:34:58 11/18/12
I often read that 5psi is the maximum pressure for testing
Dark Diver
16:17:47 11/19/12
sounds to me like you have a dead fuel injector
aliaZ
12:58:54 11/18/12
Re: sounds to me like you have a dead fuel injector
dwverzwy
13:12:08 11/18/12
A boost leak test will test the whole system both boost and
Evan_Wright (Ca)
13:39:25 11/18/12
dwverzwy
16:12:09 11/18/12
aliaZ
19:08:01 11/18/12
Re: Re: Thanks for the help - I think I know the problem -
dwverzwy
20:37:21 11/18/12
it's been pulled before if it has 555's installed
aliaZ
06:45:19 11/19/12
For future reference here is a link How TO vacuum test>
ZUL8TR
12:22:31 11/19/12
