TwinTurbo.NET: Nissan 300ZX forum - Re: sounds to me like you have a dead fuel injector
dwverzwy
on November 18, 2012 at 1:12 PM
posted by aliaZ
on November 18, 2012 at 12:58 PM
My research is leading me to see that as a good possibility also. The previous owner put 555's in but they are the older style I'll be checking this also tomorrow. I know I also need to do a vacuum test too..
Boost Leak Test vs. Vacuum Leak Test
dwverzwy
12:27:36 11/18/12
Boost leak will be between turbo and inter cooler and vacuum
craigz96tt
12:52:08 11/18/12
Re: Boost leak will be between turbo and inter cooler and vacuum
dwverzwy
13:10:50 11/18/12
I made mine but you can find a gauge with a valve stem for
craigz96tt
13:34:58 11/18/12
I often read that 5psi is the maximum pressure for testing
Dark Diver
16:17:47 11/19/12
aliaZ
12:58:54 11/18/12
Re: sounds to me like you have a dead fuel injector -
dwverzwy
13:12:08 11/18/12
A boost leak test will test the whole system both boost and
Evan_Wright (Ca)
13:39:25 11/18/12
Thanks for the help - I think I know the problem
dwverzwy
16:12:09 11/18/12
Re: Thanks for the help - I think I know the problem
aliaZ
19:08:01 11/18/12
Re: Re: Thanks for the help - I think I know the problem
dwverzwy
20:37:21 11/18/12
it's been pulled before if it has 555's installed
aliaZ
06:45:19 11/19/12
For future reference here is a link How TO vacuum test>
ZUL8TR
12:22:31 11/19/12
