TwinTurbo.NET: Nissan 300ZX forum - Re: I used the 'standard' King Bearings - rod and crank
Cjw3
on November 15, 2012 at 6:36 AM
posted by mpmarino
on November 13, 2012 at 11:28 AM
I used Clevite Standard bearings on the Last Build. I had to shim the Back side of the bearings with aluminum foil to get the clearances closed to where I wanted them..
Cj
Inspect/Replace rod bearings while in car.
300ZXpert (someday)
17:23:18 11/11/12
Re: Inspect/Replace rod bearings while in car.
Cjw3
22:27:06 11/11/12
Thank you for the helpful reply.
300ZXpert (someday)
23:29:35 11/11/12
Re: Thank you for the helpful reply.
Cjw3
06:43:45 11/12/12
mpmarino
11:28:51 11/13/12
Re: I used the 'standard' King Bearings - rod and crank -
Cjw3
06:36:34 11/15/12
I ended up going with oem bearings in the end. (n/m)
300ZXpert (someday)
12:04:38 11/13/12
